greetings, if you can help with the new device. It's a ricoh IM5000, new, it works for both copying and scanning, it normally installs it on the computer, but it won't print. It shows that it has received the document, but it says that it is waiting.no error codes . I've tried various driver programs, and the same thing happens. If anyone has any advice, I'd be grateful.
NEW IM5000 problem
then if it doesn't work, back up address-book and format the hdd, and try again, i check, there is not RTB aboutLast edited by luca72; 03-12-2025, 04:55 PM."I'll be back"👍 1 -
greetings, if you can help with the new device. It's a ricoh IM5000, new, it works for both copying and scanning, it normally installs it on the computer, but it won't print. It shows that it has received the document, but it says that it is waiting.no error codes . I've tried various driver programs, and the same thing happens. If anyone has any advice, I'd be grateful.- What type of test page
- What driver
- What port
- What is the resolution
- What are the Graphics settings of the driver
👍 1Comment
ok, this is how things are, the test is a classic Windows one, which is offered during the installation of the driver program. The driver program is PCL5, PCL6 and PCL v4. On the display it says that the test is printing and that other files are pending. The device is connected to the TCP/IP network. I used the same address from the old device. The resolution is standard and I never touched it, while the driver is only set to the size of the paper in the cassettes. Scanning via SMB to the folder works normally as well as classic copying.Comment
ok, this is how things are, the test is a classic Windows one, which is offered during the installation of the driver program. The driver program is PCL5, PCL6 and PCL v4. On the display it says that the test is printing and that other files are pending. The device is connected to the TCP/IP network. I used the same address from the old device. The resolution is standard and I never touched it, while the driver is only set to the size of the paper in the cassettes. Scanning via SMB to the folder works normally as well as classic copying."I'll be back"👍 1Comment
On the display it says that the test is printing and that other files are pending. The device is connected to the TCP/IP network. I used the same address from the old device. The resolution is standard and I never touched it, while the driver is only set to the size of the paper in the cassettes. Scanning via SMB to the folder works normally as well as classic copying.👍 6Comment
Once again I am referring to the port used not the IP address used with the port. WSD uses exactly the same IP address as SMB. Now look at the port tab of the driver properties and see what fucking port is being used.😂 3👍 2Comment
Clear all pending jobs. Set machine to DHCP. Reboot. With the machine on DHCP run the PCL6 driver installer for the IM5000 found at ricoh-usa.com. The Computer should find it on the network on the install and install the correct driver. Do a test page. What happens? Odds are it prints. Now backtrack and figure out where you messed up.👍 3Comment
Attached FilesI don't care about who your father is, as long as I'm fishing here, you won't walk on water.👍 3Comment
