Lines with feed appeared on the top.
  • Marwan
    • Oct 2023
    • 20
    Greetings all,
    recently i'm facing lines with feed apears only on the top of pages ,i have changed PCU and charge unit , also i have cleaned the cleaning unit and refresh the developer but no hope,
    any suggestion,i have added the attachment please check​
  • davel
    • Oct 2011
    • 1074
    What machine, SEF or LEF, copy or print, are you referring to the line down the page just to the left of the image as shown in your sample?
    • Larhal
      Semi Retired
      • 527
      Dirty charge roller. Drum cleaning blade failure, Drum failure.
      Larhal
      Retired Part Time
      If all else fails read the Service Manual!
      If that fails, meet me at the pub and we will discuss it.
      • Steve Tech
        • May 2024
        • 30
        All I can see from your photo is the border of the image, you can replace the drum, dev, charge etc as many times as you want but you won't get rid of that
        • Larhal
          Semi Retired
          • 527
          At the top of the images with the larger white area I can see 2 lines in the direction of the feed from each edge. Cant you see that? If it is not the 3 items you stated then what is it?
          Larhal
          Retired Part Time
            • 36685
            What I am seeing is edge shadow. It could be a skewed original. It would help if you had included what model you have.
            • Steve Tech
              • May 2024
              • 30
              To be honest no, all I can see is the border of the image.
              How do you know what the direction of feed is?
              He hasn't said!
                • 36685
                He hasn't said!
                I think it is a copy made on the platen glass with the platen cover or document feeder up. Look at the sample. There is large black mark that is wider at the bottom and a rippled black on trop long edge. That tells me that the original is not flat on the glass.
                • Popolopo
                  • May 2023
                  • 101
                  thinking the same thing. maybe the whitesheet install incorrectly or already torn
                  • Luism
                    • Dec 2024
                    • 17
                    Correct, do not look for problems in the equipment, the original is placed on the glass "floating" and does not rest correctly on the exposure glass. It is not necessary to know the feed direction of the copy or the equipment model.
                    • Larhal
                      Semi Retired
                      • 527
                      He hasn't said!
                      You may be correct. I could not tell the direction of the feed but that is what it looked like to me.
                      Also notice Marwan has not replied to this feed with any more information.
                      Larhal
                      Retired Part Time
