IM550 "Waste Toner Bottle Full"
  • laser801
    • May 2014
    • 151
    Hello All! I have an IM550 That keeps saying "Waste Toner Bottle full, but its empty... I cleaned everything.. replaced Drum Unit, and of course Waste Toner Bottle.. Any thoughts??? Appreciate any feedback, Laser801
  • dalewb74
    • Feb 2018
    • 1153
    did you clean the area once you removed the bottle?
    • laser801
      • May 2014
      • 151
      Oh yes! cleaned everything..
      • MIGUELMARCHENA
        • Feb 2018
        • 195
        I had that exact problem yesterday, and I had to remove all the caps to clean them thoroughly.
        I checked the toner auger in the drum unit and the outlet nozzle... the toner had turned into rocks and wouldn't drain into the jar.
        • luca72
          • Oct 2017
          • 1778
          that printing system should be derived from kyocera, do you happen to use compatible toner?...we had the same problem on similar kyocera machines, with the problem described by Miguel, it seems that that pcdu system does not digest compatible toner well.
          "I'll be back"
          • Mako
            • Jan 2025
            • 791
            Try a different waste bottle. Also make sure sensor is clean. Test sensor in service mode.
            I had one once that a new toner bottle fixed the issue as it wasn't playing nice with the sensor.
            • laser801
              • May 2014
              • 151
              Thanks for all the input.. Much appreciated as always, Laser801
