Cannot reach Ricoh IS 2416 via IP adress
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Re: Cannot reach Ricoh IS 2416 via IP adress
    That is why I am thinking that the scanner IP and the printer IP are different. I have installed and worked on systems set up that way.
    If I remember, the old Aficio 270 had the two separate ports.
      • 37490
      No but it did not support SMB scan to folder. Only TWAIN pull scanning and ScanRouter V2. Scan router is not compatible with any current Windows. Normally required a dedicated XP computer or NT4/4.1 server.
      • Drivee
        • Nov 2020
        • 322
        Thank you all for comments.
        As I say, I am unable to ping printer IP via cmd. I did install copier via network, I just run universal driver from Ricoh web and printer print well.
        The IP of computers are in same network. So, printer is 192.168.0.233 and lap top is 192.168.0.101, so I should be able to ping. Anyway, I did not realize that models is so old so it will be used for printing and copy until service need to be made and them we will scrap this one. It is time to replace this old machine!
