Strange problem IM C300 + Wifi = SC899
  • dave w
    • Jun 2015
    • 230
    #31
    Re: Strange problem IM C300 + Wifi = SC899
    Originally posted by Keegan Chetty
    You could also try disabling the SNMP status on the configure port option on the driver, change IP address and network point.
    they only work on a Wi-Fi natwork - only the printer is on a Ethernet port and only one port available.
    Disabling the SNMP - would that stop anything from working correctly as i have never done that before.
    Dave
    • dave w
      • Jun 2015
      • 230
      #32
      Originally posted by kleankopy
      I fixed a few different Ricoh's lately that even with new firmware it still thru 899s, so I increased the buffer from 128k to 256 in the printer feature menu/ Host interface. They have not had any more 899 since.
      Yes i did the buffer adj after your advice - still same
      Dave
      • tonerhead
        • Sep 2009
        • 582
        #33
        As mentioned httpd is they are printing from a webpage most likely on Apache server. I have had it in the past when a computer's browser is really out of date and needs updating. Best thing I can tell you is to try to find what webpage crashes the copier. See if it will print from another browser.
        Funny, everyone hates windoze updates, but how often do we update firefox or chrome browsers? If you are running linux, you would notice these update frequently.
        I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
        Especially when it comes to sex
          • 37490
          #34
          If you have you have Firefox setup properly, you will get updates automatically. And you only have to restart Firefox to install them. The same with Thunderbird.
          Most of the times that I have seen SC899 associated with a webpage, it was a webpage that an employee was not authorized to access at work such as a gambling site or online store.
          • tonerhead
            • Sep 2009
            • 582
            #35
            I stand corrected. It seems that chrome and firefox do update automatically upon starting browsers. I guess this was not the case in the past as I do remember outdated browsers causing 899 errors. I do remember about 6 years ago, java made some changes that M$ internet exploder wouldn't comply with. Printing from chrome or firefox worked perfectly, printing from IE made practically every printer choke. Ricohs would throw 899 errors. HPs would through memory errors. Just saying, if you can find out what internet page they are printing from, have them try a different browser. Dollar to a donut, they are printing from Edge. I don't think they are all of the bugs out of the new edge chromium yet. It still sucks.
              • 37490
              #36
              IMHO Edge is a POC.
              • tonerhead
                • Sep 2009
                • 582
                #37
                IMHO Edge is a POC.
                Had to think about what POC is. I'm used to POS, your's is a gentler way of putting it.
                • dave w
                  • Jun 2015
                  • 230
                  #38
                  UPDATE
                  Firstly BIG thanks to all for advice and guidance.
                  Last week I gave the customer the challenge of adding one PC at a time to the printer, upto date driver and IP port.
                  Thurday morning they started to add the first windows 10 laptop and I was updated that all was good.
                  Thursday Afternoon another laptop was added.
                  Friday I dont work as the Covid has put me on a 4 day week, but I did see an email from the customer that all was still good.
                  So far so good, no Mac pc have been added as yet.
                  Lets see what happends when the Macs are added.
                  Dave
                  UPDATE
                  The customer today has informed me that after adding one laptop at a time with correct driver and IP port config all was good until
                  one culprit caused the issue and was found to be printing via Chrome !
                  They have now got the user to do what is recomended to stop the issue from happaning again.
                  I will also tag the info Ricoh came back with.
                  via email
                  (Previous case so ip numbers not always relevant to yours)
                  Symptom: SC899-00
                  Cause: Network support firmware bug.
                  According to the log investigation, this device is accessing to only the following two addresses.
                  SC 899 occurs whenever it is accessing to #2 IP address.
                  #1. 192.26.127.19x
                  #2. 192.26.127.12x (for IPP printing)
                  Permanent Solution: The next package firmware will be applied (August).
                  Temporary Solution: IPP printing is halted via WIM (Device Management> Configuration>IPv4 or IPv6>IPP: inactive).
                  So please check if IPP is happening when the errors occur, it may well be the firmware update has helped but possibly worth disabling IPP as above to see if any help.
                  Of course, this may be irrelevant but seems they're using the Apache server and possibly an update may help? I don't know much about it i'm afraid.
                  Bulletin
                  Model: Metis-MF3 Date: 4-Feb-22 No.: RD0BL073
                  SYMPTOM
                  SC899 may repeatedly occur when printing from Windows 11 using IPP (Internet Printing Protocols) such as Mopria.
                  Affected products:
                  IM C6000/C5500/C4500
                  IM C3500/C3000/C2500/C2000
                  CAUSE
                  Data printed via IPP from Win. 11 contains RFC noncompliant data. As a result, SC899-00 can occur due to the abnormal end of HTTP communication.
                  SOLUTION
                  Update the package FW to Ver.5.29.1 or newer.
                  Product Package (ALL) Version Package (ALL) Software Part Number
                  5.29.1
                  D0BN5559E
                  5.29.1
                  D0BL5559F
                  Reference information of fixed module Product Module Version Software Part Number
                  IM C6000/C5500/C4500/ C3500/C3000/C2500/C2000
                  Network Support
                  18.89
                  D0BL5578Y
                  • tonerhead
                    • Sep 2009
                    • 582
                    #39
                    Did they say what they were printing in Chrome? I haven't seen it much lately, but it used to be if they were printing a pdf email attachment online, that might cause sc899. The key was to download the attachment, then print from the downloaded file. In my mind some of it was a delay between the internet and spooling the print.
                    • dave w
                      • Jun 2015
                      • 230
                      #40
                      Yes that is what he was doing.
                      Lets see if he mends his ways!
                      Dave
                      • DRichard
                        • May 2008
                        • 482
                        #41
                        IMHO Edge is a POC.
                        (You misspelled POS)
                        "Enjoy every sandwich."
                        -- Warren Zevon
                        • tonerhead
                          • Sep 2009
                          • 582
                          #42
                          No he is being polite. POC= piece of crap
                            • 37490
                            #43
                            In the computer information arena POS means Point Of Sales.
                            • DRichard
                              • May 2008
                              • 482
                              #44
                              Even MORE polite...
                              Piece of Cheddar
                              Piece of Cracker
                              Piece of Cat
                              Piece of Corn
                              Piece of Canoe
                              Piece of Carrot
                              I could go on...but POS IS the more polite form of 'Piece of shit' after all.
                              -- Warren Zevon
                              • tonerhead
                                • Sep 2009
                                • 582
                                #45
                                Even MORE polite...
                                Piece of Cheddar
                                Piece of Cracker
                                Piece of Cat
                                Piece of Corn
                                Piece of Canoe
                                Piece of Carrot
                                Or as our British copy techs say
                                "Piece of shite"
                                Used to know a tech that used to say "Piece of Donkey Dung"
                                If I know a customer good enough, I might blurt out "you gravy sucking pig, piece of art" when I drop a screw.
