Ricoh Pro 5100S Fiery does not show on touch panel
  • tulintron
    • Jul 2014
    • 668
    Good morning people.
    After a technician runs SP5801 on the printer, my fiery does not appear on the printer panel.
    Is there any bit switch or command to enable this function?
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh Pro 5100S Fiery does not show on touch panel
    Why on earth did the engineer memory clear it? Follow the Fiery installation instructions in the service or Fiery manual, several SP modes need to be changed.
    Hit it.
    • copier tech
      • 8144
      I don't suppose he had the intelligence take an NVRam back up before he ran that all clear?
      If not this machine will have all kinds of issues.
      Read the service manual it explains what SP settings you need to change back.
      • Zaxxon
        • 608
        Start with typing in the SP from the birth certificate. After that do the Fiery installation from the manual.
        Without the birth certificate your machine is toasted.
        Please start you post with brand, model, problem.
        • satins
          • Feb 2021
          • 89
          Please find the attached process.
          • tulintron
            • Jul 2014
            • 668
            Thank you guys. I didn't want it to be like that, but it all worked out.
            • tsbservice
              Field tech
              • 8016
              Good to know you're on safe side
