mpc4503 paper internal exit tray curling
  • digicor
    • Jul 2008
    • 1152
    question? is there a different exit roller assembly for the 4503 like the 6004 etc if you have no fin on the 6004 it takes a different exit roller assmbly than if you do have a fin then its the different exit roller assmbly, does the 4503 need the same thing switched with or with out a fin? i cant see where it would be changed in the front like the 6004 etc,, does the whole assembly need changed out directly behind the fuser? this piece does come out relatively easy. or the 4503 does not have the same situation as the 6004? thanks for any insight, There is NO FIN on this machine just internal paper catch.
    • 37044
    Re: mpc4503 paper internal exit tray curling
    Nope. If you are getting curling on exit, you have excessive moisture in the paper in the feed tray. You may need to install the tray heaters.
    • anothertech
      • 1757
      Try lowering the fuser temperature.
      • digicor
        • Jul 2008
        • 1152
        i did just that by 3 degrees just to see, i never like to go to low in these cases, im waiting to hear back from client to see if it still does it, I think they had moisture in the paper, the machine didnt do it at install and its been installed for about 2 months this is the first ive heard of it, Thanks for the suggestion
        • tonerhead
          • Sep 2009
          • 582
          We ended up installing tray heaters on mp4054 with similar. That actually did work nicely for us.
          I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
          Especially when it comes to sex
          • Mark Bbb
            • Jun 2012
            • 1662
            Jep, here also
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              If the machine is a used machine and once had a finisher installed yes you have to replace back to machine only exit roller assy. When fitting a bridge unit or internal finisher you get a roller assy in the box.
              Regards Mark
              • digicor
                • Jul 2008
                • 1152
                would u happen to know the part number by chance? thank you, i assume its the assembly right behind the fuser unit
                  • 37044
                  It is in the parts catalog D2414950 ROLLER:EXIT:PRESSURE:2TYPE:ASS'Y
                  • digicor
                    • Jul 2008
                    • 1152
                    that only lists for the 4505/6004etc,, its the same one for 4503? if so i have it
                      • 37044
                      Sorry about that, I was in the wrong model folder. For the 03 models, the installation of the bridge unit does not require changing the roller.
                      • Gift
                        • Mar 2011
                        • 2455
                        Wasn't there a modified internal output tray available for the metis with a partially spring-loaded tray catching the paper before it could start to curl?
                        If that's not enough you can sneak to a parts donator and get yourself a "2nd hand" duplex output tray (that one directly below the scanner) and lay or hot glue it on the internal output tray. This "solution" might decrease the internal paper stack capacity a bit, though...
                        Plan A is to check the paper quality of course...
                        • tonerhead
                          • Sep 2009
                          • 582
                          I wonder if you could modify the exit plate and guides from an IMC4500 to work? They are parts d241-4972 and D0BQ-4960.
