Re: Ricoh MP C2801 firmware update failed
absolutely yes!...the more machines you go back, the less they support large sd, I suggested 150-200mb to be sure, but I also think 500mb or maybe 1gb are usable, to partition I use "minitool partition tools" for windows 10 (this function its free) but whatever you want is fine, put just the "system copy" for now, then do the others...the fast way its to use a old java sd card from scrapped machines...usualy are low capacity
https://www.partitionwizard.com/free-partition-manager.html
