IM4000 stuck on "Waiting for firmware update data"
  • DRichard
    • May 2008
    • 482
    #16
    Re: IM4000 stuck on "Waiting for firmware update data"
    Originally posted by UNICORNico
    Does it not start to be something repetitive, that several devices are giving error with online updates?
    At the moment I deactivate the entire remote update process, and I prefer to update the firmware individually, as required and with my reliable SD Card. If it is essential, always the ENGINE, SYSTEM COPY, and those related to the network.
    The truth is that little should need to be updated, when network protocols take years to modify. For example the SMB.
    Same here. I ALWAYS update via SD or USB device. I also archive older FW whenever possible (just in case).
    "Enjoy every sandwich."
    -- Warren Zevon
    • j2shortt
      Learning to speak PCL...
      • Feb 2019
      • 56
      #17
      Spoke with Ricoh. Simple, short, and sweet response.... replace the control board, NV ram, and HDD individually in that order.
      • DRichard
        • May 2008
        • 482
        #18
        So...they have no idea. (Makes one wonder what kind of commission their service support techs make off of selling parts...?)
        -- Warren Zevon
          • 37490
          #19
          Were you talking to the Ricoh-USA support desk or to your regional dealer support person? More often than not the US support desk is just reading what is on their database and have been out of the field so long that they have forgotten good trouble shooting techniques.
          • tsbservice
            Field tech
            • 8016
            #20
            Originally posted by Gift
            Is it possible to get the ten key pad on the display? In this case it could be a chance to try the Yellow143+several times "C" combo to tell the machine not to display that message again so you can boot it with SD card and start the update from scratch.
            FUBAR is military slang for "fucked up beyond all repair"...and they have a lot of them meaning almost the same.
            P.S.
            One of my favourites is SNAFU - Situation Normal: All Fucked Up - just like today at work
              • 37490
              #21
              P.S.
              Then there is always BOHICA, Bend Over Here It Comes Again
              • tsbservice
                Field tech
                • 8016
                #22
                Lol 🤣
                I'm not going to get the lemon machine install again near future.
                It was real FUBAR... but hey after few beers i'm back to normal SNAFU
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  #23
                  Just spoke with one of my out of state teammates today.
                  He had a similar issue on an IM4000 when using the ACT function.
                  It updated OK (not known if it used the most current version or not), but SLNX got messed up, and needed to be reinstalled.
                  I checked the firmware history, and there was no mention of that wonderful little side effect.
                  Good thing he didn’t allow the same update on the rest of the IM4000s at the same account; they have a boatload of the little gems.
                  • Gift
                    • Mar 2011
                    • 2459
                    #24
                    P.S.
                    LOL sweet
                    • emiliorsg
                      • Jul 2018
                      • 141
                      #25
                      It seems to me that they gave you the typical response of a call center, which comes from the database.
                      • j2shortt
                        • Feb 2019
                        • 56
                        #26
                        Yea, it was Friday evening before memorial day weekend. The tech was just trying to close the call. And the tech was 1st level support. I got a loaner in place. Ate up the majority of my day.
                        • anothertech
                          • 1769
                          #27
                          Did you try "Reset 143 Clear Clear Clear"?
                          also try "Reset 143 Clear Clear Clear Clear Clear"
                          If that is successful, it should beep twice, then reboot.
                          • j2shortt
                            • Feb 2019
                            • 56
                            #28
                            Yea, special and regular service mode were met with unresponsive OP panel... Lame....
                            • j2shortt
                              • Feb 2019
                              • 56
                              #29
                              So after a bit of the "Waiting for update data" message i get the beeps and flash of red SC code screen. it displays then the "waiting for update data" overlay displays over the sc code display so its only visible for like a tenth of a second. so i turned my FPS up on my phone camera and recorded the screen. then after going frame by frame i can see its getting an SC878-01 which is USB flash error. I've never seen this one before.
                              oh boy......... <insert my fake happy face>
                              • j2shortt
                                • Feb 2019
                                • 56
                                #30
                                Re: IM4000 stuck on &quot;Waiting for firmware update data&quot;
                                pic below of SM entry of the SC code
