Ricoh 2035 error code SC 395 ???
  • quocanh83
    • Jul 2025
    I have Ricoh 2035 error code SC395, what's matter? How's resolve? Thanks anybody help me.
  • fitsy.13
    senior tech
    • 64
    the 395 is a c code and relates to delelopment output abnormal.a development bias leak signal is detected high voltage to the dev unit which eceeded the upper limit
    try seeing what state your mag roller are and clean them then redev it and set it back up in the sp mode
    • mikadonovan
      • May 2008
      • 2931
      Not to be a smart ass, but you may get more feedback if you post this problem on the copier Ricoh/Savin/Gestetner forum intead of printers.
      NEVER ASSUME ANYTHING
