They are great machines if run at or below recommended volumes. Ricoh made a lot of improvements with the machine through new firmware, so if you get some in, update the firmware before they go out in the field.
Thinking of replacing some of my rental machines with these. Are they reliable that is not prone to misfeeds/jamming???
Thanks!!!!
First of all same as it ever was... it depends on your location, usugae profil, (paper)quality and behaviour (of user) . The toner replacement is a litle bit tricky but tradable. The adf is sensitive during paper feed entrace for folded paperdocuments. On the whole in my opinion a nice compact bw machine.
Thanks!!!!
we have a few around, it generally works well, personally the only things I have encountered are, it has the pcdu a little weak, and the rdf hinges tend to unscrew, but nothing serious if you know it
