replacing HD in a Savin C3535
  • halac0ax
    • 18
    I'm hoping someone can give a bit of help. I'm trying to replace the hard drives in a C3535. I've tried every jumper combination, tried formatting them numberous times, but I keep getting SP 990 code. If I unplug the HD's I can make copies but every other fuction is gone. I am using non ricoh HD's BTW.
    Anyone have any ideas??
  • Jomama46
    • 2900
    Jumpered single drive or master and no slave.
    Formatting or partitioning not necessary as the machine will perform this on its on.
    Perhaps the drive is defective. Stick it in a pc and run Seagates sea tools or other drive utility on it.
    sigpic
    A+; Network +; PDI+
    • halac0ax
      • 18
      Tried all those things already. The HD all check good. I really don't think that its the controller board. I'm starting to think its something Ricoh does to the HD's.
      • Jomama46
        • 2900
        No, I've replaced too many of these drives. I just take it out of the wrapper hook it up and turn the machine on. Period. Maybe you have a bad data cable.
        sigpic
        A+; Network +; PDI+
        • KopyKat
          Nurse Ratched of Repair
          • Nov 2008
          • 365
          On some of the machines which have more than one hard drive, as this one does, The HDs are formatted a special way with RAID from what I have been told. Which in turn forces you to use the Ricoh drives as a set. I haven't replaced one on this model yet (Ricoh MP3500).
          If anyone knows of a trick for the MFPs with multiple drives please post it!!
          sigpic
          Relax! This firmware injection won't hurt...but it will take 45 minutes.
          • FRIDGEMAGNET
            • Aug 2007
            • 377
            This does use 2 HDDs and I always fit an exact pair and they work straight off.
            • Jomama46
              • 2900
              You're right kopykat. And altho, the RA says that formatting isnt necessay at replacment, it assumes you're using Ricoh parts.
              Maybe try replacing both HD's at once. Match the jumpers.
              If it still fails, I guess you're stuck with the OEM replacment
              sigpic
              A+; Network +; PDI+
              • halac0ax
                • 18
                Thats what I was thinking that I'm going to have to use OEM HD's. The ones that I tried to replace with have the same stats as the original ones except the names (OEM -Hitachi After - Western Digital). Both are 7200 RPM 40 GB, etc. The machine will see the HD's but refuses to do anything with them.
                • KopyKat
                  • Nov 2008
                  • 365
                  I believe that's because Ricoh formats them in a RAID configuration. If we could figure out the configuration they use and could duplicate it somehow it would be great. But try and pry that out of Japan!
                  sigpic
                  • unisys12
                    • 489
                    I might be totally wrong, but I think I remember that these multi-hard drive systems use RAID 3. If I remember correctly, it has to do with the transfer rates offered, as well as the ability to recover corrupted information that more often than not might happen. More info on RAID, not RICOH related, can be had here... Standard RAID levels - Wikipedia, the free encyclopedia
                    Hince the fact that you have to replace all drives at the same time, unlike a mirrored system such as RAID 0. Either way though, it shouldn't matter what the RAID level is, just that you have a good drive with a good connection to the controller. As well as a good controller, not to mention the software to go along with all those things. And yes, since it's a RAID configuration, formating should be done. Now! Weather that is done at boot automatically or should be manually run, through SP's... I have no idea. I've personally never had one of these with a dumped drive.
                    Fingers are now crossed, since I have now jinxed myself. Luckily I just got in two new 80 gig serial drives in from tigher direct, so... what the hell, bring it on!! I've got `til five!
                    sigpic
                    The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
                    • halac0ax
                      • 18
                      What I'm doing is more of a test, then anything else. We've had a rash of drives going bad. I've swapped both drives at the same time and the machine just gives me 990 codes. Tried formatting in SP mode and nothing. I'll take a look at Raid 3 info.
                      Hal
