MPC3300- Scan to USB/SD device
  • Ikondave
    • Mar 2025
    Hi,
    We have placed (3) MPC3300's at an account and are trying to set up the "Scan to USB/SD device"
    We are getting a 'USB device not recognized' on all 3 machines. Clearly it's not the machine malfuntioning since all 3 are doing the same thing, but Ricoh is not sure and we can't seem to understand what we are missing.
    I know these are not common accessories. Wondering if anyone has any experience setting these up?
    I attached a picture of the device.
    Thanks!
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Looks like not all usb mass storage devices are supported (maybe more will be supported with a firmware update at some point)..
    Here is a list of tested storage media from the tier2 support site.
    • Buffalo RUF-C1GS-BK/U2 1GB
    • I/O Data TB-BH2/2G/B 2GB
    • I/O Data TB-AT1G/S 1GB
    • I/O Data TB-ST2G/B 2GB
    • elecom MF-AU202GSV 2GB
    • elecom MF-NU201GBK 1GB
    • Sony USM1GLX 1GB
    • Sony USM2GL 2GB
    • Sony USM1GJ/P 1GB
    • SanDisk SDCZ7-1024-J65B 1GB
    • SanDisk SDCZ7-2048 2GB
    • SanDisk SDCZ4-1024-EB10 1GB
    • SanDisk SDCZ12-2048-E11 2GB
    • Kingston DT400/2GB 2GB
    • Kingston DT110B/2GB 2GB
    • Trancend TS1GJFV30 1GB
    • Trancend TS2GJF160 2GB
    • Trancend TS2GJFV30 2GB
    • Princeton PFU-2XS2GS 2GB
    • Princeton PFU-2TB512 512MB
    • Imation FlashD-Mini128 128MB
    • Imation FlashD-Mini256BL 256MB
    • Lexar JDFF512-431 512MB
    • Kodak KUSBFF1GSCSC 1GB
    • PQI BF07-1035R 1GB
    • Hama CLE USB 1GB
    2Gb would seem to be the maximum size you can use going by that list.
    • Ikondave
      Thanks Cipher...I just threw this thought out to the tech and he said it's even before you plug a flash drive in. It's as soon as you hook up the accessory to the machine, then each machine codes out. Sounds like Firmware but we are definitely missing something in this set-up!
      • slot
        • Jul 2008
        • 341
        I have only set one up and found i had to try 3/4 memory sticks to get one that would work
        • FRIDGEMAGNET
          • Aug 2007
          • 377
          Something we only found out recently is that the manual says to turn on SP1013-001.
          It does not say this is in scanner SP.
          The one I set up worked with my 1gb card and the USB stick that the card slots into.
          • Llama God
            • Mar 2009
            • 1353
            I've never installed one of these myself but, looking at the manual, make sure that the USB cable is in the correct slot on the controller and enable SP1013-001 like Fridgemagnet said.
            Oh, and blitz the firmware too, just for shits and giggles.
            • aabarnes1
              • Mar 2009
              • 620
              usb
              The USB must be 2Gb or LESS for it to work also not all brands work, like the shit they have in Argos. You must also format the stick or card to FAT
              Grant me the serenity to accept the things I cannot change.
              • Fearless V K
                • 620
                Don't take that toner with me!
                • Rorschach
                  • Nov 2008
                  • 65
                  There are some larger flash drives that will work. Used my Kingston 8Gb the other day on one of these bad boys.
                  Today's subliminal quote is:
                  • Ikondave
                    Great info everyone...I'll let you know what it was once resolved!
                    • ahgoh7
                      i had the same problem once on other models. found out that the usb device i'm using is formatted to NTFS. I bought a new pendrive which is running on FAT. the mfp detects it and scanning can be done easily. Remember to put nothing more than 2 Gigabyte device.
                      have a nice day!
                      • Ikondave
                        Fixed!
                        Just a heads up to all, thanks for all the responses. My tech told me he made a second effort to get this done and apparently he had a step out of sync. You need to follow the steps to the letter and if you are out of sync with an SP entry it will not work. Thanks again!
                        • unisys12
                          • 490
                          I haven't had any of these yet, thanks for thread. Very informative!
                          sigpic
                          The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
