unusual lines in sheen/gloss. Please take a whack
    • 37490
    #16
    Re: unusual lines in sheen/gloss. Please take a whack
    It most likely is the same as either the 2232C or 3228C. Check the diameter of the hot roller. THe roller for the 2232C is 29mm and the 3228C is 29.5mm.
    Parts numbers
    for 2232C AE01 0037 Hot Roller:Mm29
    for 3228C AE01 0055 Hot RollerIA29.5
    There is also a gear black Bakelite gear on the back, drive input gear, that these beasts are notorious for taking out.
    • Patrick T
      • May 2023
      • 23
      #17
      Parts numbers
      Thanks. It was the 0037. I found one relatively affordable. Now i have to decide if im up to the task. Ive never tore a fuser apart.
        • 37490
        #18
        Private message me if you need any of the manuals. Disassembling the fusing unit is a lot easier if you do it by the book.
        • Patrick T
          • May 2023
          • 23
          #19
          Final update- spongy hot roller replaced fairly easy with just screwdriver and ring pliars and a glove to handle the heat lamp. And schematics (thanks slim). Works like a charm, clean images. All good. Thanks again.
            • 23008
            #20
            Congratulation on your success. =^..^=
            • luca72
              • Oct 2017
              • 1778
              #21
              Bravo!...that machine, if I remember correctly, has a very complicated fuser unit, it can be seen that it has been standing still for too long.
              "I'll be back"
              • GIUBOSS
                • 1435
                #22
                I found new flat spongy rollers also on other models and in the technical bulletins they wrote that they would normalize with use, replaced anyway because then they made noise as well as corrugating the paper. There is also an oiler roller and another in aluminum which should be replaced periodically.
                • Patrick T
                  • May 2023
                  • 23
                  #23
                  Thanks for heads up. I thought there might be tech bulletin but was unable to find
