Re: unusual lines in sheen/gloss. Please take a whack
It most likely is the same as either the 2232C or 3228C. Check the diameter of the hot roller. THe roller for the 2232C is 29mm and the 3228C is 29.5mm.
Parts numbers
for 2232C AE01 0037 Hot Roller:Mm29
for 3228C AE01 0055 Hot Roller
IA29.5
There is also a gear black Bakelite gear on the back, drive input gear, that these beasts are notorious for taking out.
Parts numbers
