ricoh mp c5503 - error sc569
  • tullio
    • Feb 2012
    • 268
    problem ricoh mp c5503sp - error sc569 - 00
    ricoh mpc5503 problem, sc569 error. I turn it off and on again, after two prints the same error.
    thank you - urgent
  • mikadonovan
    • May 2008
    • 2931
    Re: ricoh mp c5503 - error sc569
    Depressurizing Error Detection
    NEVER ASSUME ANYTHING
    • mikadonovan
      • May 2008
      • 2931
      Pull out the fuser and look to the left. The sensor is inside the cavity. I have seen them knocked out of position before, and sometimes they just need cleaned.
      • TonerMunkeh
        Professional Moron
        • 3865
        Replace D1751357.
        Hit it.
        • sandmanmac
          • 3981
          thank you - urgent
          WOW! That's some mighty fine trouble-shooting there Tully.
          I hope you didn't get your hands dirty
          • tullio
            • Feb 2012
            • 268
            Today i'm going to see - i'll update you -
            • tullio
              • Feb 2012
              • 268
              I've solved it for now. I lubricated the fuse unit - thank you very much - made 100 test prints, all ok.
              • DRichard
                • May 2008
                • 482
                Well...I guess it's always better to have lube and not need it, than to need lube and not have it.
                OR
                Professor Harry Block (Orlando Jones) right before quick invasive surgery is done on him to remove a rascally alien parasite. As Block screams to his compatriot Dr. Ira Kane (David Duchovny), “There's always time for lubricant!”
                "Enjoy every sandwich."
                -- Warren Zevon
                • luca72
                  • Oct 2017
                  • 1778
                  I don't think what you've done will last long, the problem (indeed) depends on an excessive amount of grease applied to the bushings of the pressure mechanism in the factory assembly phase, which over time penetrates the one-way bearings making them ineffective, you have to disassemble the group pressure, and thoroughly clean/wash with alcohol and rags, both unidirectional bearings in the assembly! (on ricoh there is also an RTB), there is also the possibility that it is the motor, but personally it never happened to me, and I fixed a dozen
                  I'll forward the link to another thread
                  https://www.copytechnet.com/forums/r...ighlight=sc569
                  its another model, but the procedure are identical
                  "I'll be back"
