does anyone have the FW and the apps software? for the op panel for the mp c6004? I have a sick puppy and need to replace the FW,, i have the blue starburst and nothing else
thanks
thanks
Have you tried unplugging the hard drive? Have you tried removing accessory electronic boards... I don't think a FW update can start if the machine doesn't start correctly first.
thanks
We can supply this for you if it's still required.
Are you able to enter the SOP android service menu/recovery mode? I think you must get that far in order to be able to rewrite the FW or perform a (factory) reset. I was told not to perform factory resets on SOP but it helped me in the past lol.
I can send you the file in case you are still in need.
