ricoh 2075
  • hodgiepodgie
    • Jul 2008
    • 284
    ricoh 2075
    connected a B469 FINISHER AM GETTING ERROR SC 741 DOES NOT MAKE SENSE THERE IS NO REAR SADDLE STITCH STAPLER INSTALLED ANY IDEAS WHY IM GETTING THIS ERROR.B469 FINISHER IS COMPATIBLE WITH B141.
  • df3036
    • 109
    Double meaning
    Sure it's not the stapler rotation?
    This series is bad for having double meanings...
    Dave
    Kittens give Morbo gas.
    A+, Network+, Server+, PDI+
    • bonnie750
      • 302
      Favourite on these finishers is the harness, had quite a few strange faults called when they are damaged/worn. the damage usually occurs where the harness is dragged across the lower frame as the slide is moved in and out.
      • hodgiepodgie
        • Jul 2008
        • 284
        well i should have tried this yesterday.finisher tray 2 broken.wierd so problem caused by f t 2 being broken so at start up get error
