Ricoh AP 610N with SC760 error
  • patterson70
    • May 2010
    • 599
    Hello, has anyone run into this code SC760 on an AP610N?
    I cannot find any direct info about this, just general suggestions.
    I know this printer is old. Does anyone still have these in the field?
    Not sure if it worth pursuing.
  • UNICORNico
    • May 2018
    • 308
    Re: Ricoh AP 610N with SC760 error
    Are you sure the error code is "SC760"?
    According to the manual we have, that code does not exist.
    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
      • 37490
      Not specifically shown in Goose's Guide for the AP 610, but for other printers, it has to do with the finisher punch motor.
      G133 SC 760 Finisher punch motor error - check/clean/replace punch HP sensor (chads)
      G133 SC 760 Finisher punch motor error - check for binds slowing motor
      G133 SC 760 Finisher punch motor error - check connections to punch unit
      G148 SC 760 Finisher punch motor - Motor bound / obstruction
      G148 SC 760 Finisher punch motor - Motor defective
      G148 SC 760 Finisher punch motor - Punch HP sensor defective
      G148 SC 760 Finisher punch motor - Check harness and connections
      G179 SC 760 Finisher punch motor error - check/clean/replace punch HPS
      G179 SC 760 Finisher punch motor error - check for mechanical binds overloading motor
      • patterson70
        • May 2010
        • 599
        Oh sorry, I meant SC670
          • 37490
          670 Engine response error
          • Engine board installed incorrectly
          • Engine board defective
          • Controller board defective
          G091/G094/G095/G112-G116 SC 670 Engine response error: Defective engine board
          G091/G094/G095/G112-G116 SC 670 Engine response error: Defective controller
          Since neither of those boards are likely to be still available unless you have a loose connection your out of luck
          • patterson70
            • May 2010
            • 599
            Thank for this. I was hoping someone has had this code and it turned out to be a loose connection.
            As a matter of fact, has anyone seen this error code at all?
            And if so was it a board or just a connection?
            I know this is a reach being an older model.
              • 37490
              With newer MFPs it is usually the USB cable between the controller and the display.
              • patterson70
                • May 2010
                • 599
                Is the loose connection more at the display? Maybe the machine gets rough handled and the cable loosens up there?
                If so then you have to remove the display to get to it?
                  • 37490
                  My experience has been at the controller. Unplug and reconnect usually takes care of the error.
                  • UNICORNico
                    • May 2018
                    • 308
                    In my opinion, this type of "connection failure" may be due to microparticles that accumulate over time or some type of static interference.
                    I'm glad to read that the problem was resolved.
                    • anothertech
                      • 1769
                      Who said it was fixed? I didn't see it
                      • UNICORNico
                        • May 2018
                        • 308
                        I misunderstood, sorry for the confusion.
