Ricoh IM 6000 Fax Help
  • kleankopy
    • Feb 2016
    • 114
    I have a PIA customer who i am replacing a canon (Maybe) that when it receives all the fax pages it prints them all out at 1 time. The Ricoh Prints 1 at a time. They want all faxes to print when they are all done receiving. Anyone know where this setting is. I would have to think this machine could do this if Canon does.
  • copyboy99
    • Jan 2020
    • 24
    Re: Ricoh IM 6000 Fax Help
    try FAX SP - 1101-032 (1F) set bit 3 to 1
    • kleankopy
      • Feb 2016
      • 114
      Thanks I found that a couple hours ago and it worked.
      • dalewb74
        • Feb 2018
        • 1153
        good think you figured it out. but since canon doesn't build ricoh? not that i am aware of. then you cant expect something that works on canon to work on ricoh, or vice versa. that would be like me pulling parts off a ford and expect it to work on a dodge.... but kudos on it actually working. i would say you got lucky.
