If anyone has to change the Drive Unit to solve a 'PCU Not Seated' Error, due to the RJ-45 Type of connector broken, be aware that the new drive units come without one set of HVPS leads, and they are also minus the dev. drive gears. It's a good idea to set the old drive unit and the new one side by side, and see what was not included. (Believe me, I'll be doing this with all new ass'ys from Ricoh from now on.)
MPC2500 Drive Unit
The female connector that the PCU actually docks into It is actually part of the Drive Unit Assembly, and is a major pain to change.I had to change it because the connector was broken.Most of the time the operators need fixing, not the machine !!!Comment
I haven't replaced one YET, as I said I did glue a K one back into place after the wing snapped off . Is the procdure in the manual or is it like having sex for the first time when your a teenager,(fumbling in the dark without a bloody clue as your blood pressure increases)?Grant me the serenity to accept the things I cannot change.Comment
I haven't replaced one YET, as I said I did glue a K one back into place after the wing snapped off . Is the procdure in the manual or is it like having sex for the first time when your a teenager,(fumbling in the dark without a bloody clue as your blood pressure increases)?Most of the time the operators need fixing, not the machine !!!Comment
You can not order just the connector as a part...(it's not fun how they make it..for a connector that is 50c you must order a part that is 4 digits$). Good luck.Comment
BIGBOY
I had a coworker that just received (complete drive unit). It's not a big deal when you will see the part. It's huge...and expensive. When you will have it you figure it in 2 minutes how to replace it.
