Ricoh IM 2500-5000 Sc 142-12 Code
  • Hoosierdaddy
    • Oct 2016
    • 181
    Anyone having SC142-12 Codes coming up? There is a Bulletin that came out that said they were working on a Resolution but havent seen anything yet.
    Thanks Hoosierdaddy
  • dalewb74
    • Feb 2018
    • 1153
    Re: Ricoh IM 2500-5000 Sc 142-12 Code
    is that a imC?
    • Bourriks
      • May 2016
      • 38
      Isn't SC142 an issue with reading the white band under the scanner glass ?
      Have you tried cleaning all the optics (lamp + glasses) ?
        • 37489
        SC 142-00 is. I have never heard of SC142-12 on ant model.
        • apump
          • Mar 2009
          • 160
          There is a tech bulletin on this. 3 steps, 1st reboot device. 2nd is to power it off, after power is off and unplugged push power button again to drain power supply, and wait 20 minutes then power it on. this usually fixes it. I have had this fix 3 out of 5 devices. 3rd is to power it off and leave off overnight. If it still has code, you will need to replace scanner carriage assy. its easy. D0DL1640
          • anothertech
            • 1769
            The step 3 I found in tech pub D0CC/D0CE/D0CF/D0CG/D0CH – 008 reads
            3. Power off and unplug the machine.a. Press the power switch for 5 seconds to discharge.b. Install the new modified IPU Board, PN D0CH5651 c. Plug in the AC Power cord and power on.d. Reconnect Fax and Ethernet cables.
            • luca72
              • Oct 2017
              • 1778
              This is how I solved it on the phone a month ago... except unplugging the network cable
              "I'll be back"
