PRO C900 Factory Mode
  • bier trinker
    • 12
    Can anyone help me with the new Factory Mode code. I tried the 143 code and it will not work. Have been getting SC333 codes, and swapped some boards, now I need to change some setting's that are only in Factory Mode. HELP!!!!
  • bonnie750
    • 302
    The usual method is used to access the sp mode, what is factory mode?
    • imaginemoko
      unTrusted Tech
      • Jan 2008
      • 289
      sc 333
      D
      Toner supply error: C
      -002: C, -003: M, -004: Y, -005: YMC, -006: All colors)
      fix the customer first then fix the machine... its simple and makes life more easy.
      • tcs04
        FORMER Techie
        • 1183
        This may be a silly question, but have you checked for a blockage in the toner bottle? I have just returned from the course. The trainer indicated that the toner bottle can become blocked at the exit due to hardened toner and requires some SERIOUS shaking / banging (!) to overcome the problem. This may cause SC333 (?)
        • jakpong
          The following is from the RTB
          SYMPTOM
          Regardless of the amount remaining, SC 332,333,334,335 or toner empty are displayed.
          CAUSE
          Due to the solidification of the toner itself, the toner supply tube (flexible tube) can become
          clogged.
          SOLUTION
          The interior of the toner supply tube (flexible tube) is to be vacuum cleaned every 400K
          PM.
          Do not keep the Toner bottle in the standing position.
