hello everybody out there!
the problem i m posting is related to Ricoh geljet series printer, the print quality issue. for the print quality its bad even when newly installed, the nozzle check is never ok or even if gets ok the print is still having lines on it. head cleaning n flushing is only a temporary solution to this. i went thru adjustments of paper feed n head alignment n tried updating the firmware but still its not good.
anybody with sum good idea, else than setting it to fire...
