Hi All,
I have a MPC2500 with a B800 PB3000 paper bank. I have a misfeed problem with tray # 4 only. I can feed a job from tray 4, set to any paper size, and it will feed fine up to the very last sheet of the job. The last sheet will pull halfway in and stop. The machine gives the finished job tone and goes to ready. Even though that sheet of paper is blocking a sensor, it DOES NOT show a misfeed. If you then try to start another job feeding from this tray, it will then show a misfeed as it already has a sheet in the paper path. This sounds suspiciously like a firmware malfunction. The bank firmware level is the original version. Can someone send me the latest version or give me some advice on this strange problem? Thanks.
mikadonovan@yahoo.com
