ricoh 2090 waste toner full message
  • bronxizzy
    • Mar 2008
    • 23
    how do u clear waste toner. reset count but still getting message. appreciate any help
  • mtech
    • Mar 2007
    • 307
    The machine has two waste toner sensors. Check out the attached file. The toner bank is probably the issue. We had a bunch of these popping codes and this bulletin was the fix. don't forget to clean up the auger system first. Good luck![ATTACH]1505[/ATTACH]
