Ricoh FT4727 fuser gears PN?
  • JimS
    The idler gear caused some jamming and eventual damage to the fusing unit Drive gear on my FT4727. I have a replacement idler gear.
    I need to replace the worn Fusing Drive unit gear, the 30z gear preceding it ( I think the pn is AB013344) which is on the fusing unit drive release mechanism. there is a small idler gear before the 30Z gear and it seems ok. The white drive gear preceeding it has been de-toothed. It has two drive belts riding on it in addition to the damaged gear.
    Can anyone help with the part numbers for the above? If you have any of the above I would be interested in purchase or a good supplier lead. Someone forwarded some pics of the above but it did not include the part numbers. The ricoh is getting up in age but has been well maintained otherwise and should be useful once again.
  • Kopyrtek
    Copier Psychologist
    • Jan 2007
    • 407
    If the gear is even available you cant a contract on it.The machine is out of of service parts wise and you can get a digital replacement for much less.Even if you own it you can get better.Just get a new machine!
    • Vulkor
      • Jun 2009
      • 946
      Introduction Date:
      9/1/1992
      Discontinuance Date:
      5/1/1996
      Termination of
      Parts Availability :
      NA
      Final Parts Assured Availability :
      4/1/2003
      Final Assured Field Support :
      5/1/1998
      Years since Discontinued:
      3.7
      Age of Product (Years):
      3.7
      Years Supported:
      2
      • Vulkor
        • Jun 2009
        • 946
        I googled and searched and searched. I found all kinds of hot rollers and such, but NO Gears and No complete Fuser Units.
