Aficio 2075 help
  • Jomama46
    • 2900
    GET OUT
    sigpic
    A+; Network +; PDI+
    • aabarnes1
      • Mar 2009
      • 620
      Just read this post and nearly pissed myself laughing, what a howl ! That post really reflects the nature of our business, people not understanding, people talking different languages, the guys at the top denying all knowledge and still the poor fuckin tech is left holding his todger wondering what the hell to do and where his life went wrong and why did he ever go on that electrnics course all those years ago!!!
      Grant me the serenity to accept the things I cannot change.
      • imaginemoko
        unTrusted Tech
        • Jan 2008
        • 289
        wild guess his problem is making copies from ADF that his original is face down....
        Sir Can06,
        fix the customer first then fix the machine... its simple and makes life more easy.
        • Ricohlovers
          • May 2009
          • 59
          #19
          Copy Face up or Down
          You can change copy face up or down in user mode.
          USER TOOLSInput/Output
          Switch to Batch
          SADF Auto Reset
          Rotate Sort: Auto Paper Continue
          Auto Sort
          Memory Full Auto Scan Restart
          Select Stapling Position (Top Left)
          Select Stapling Position (Bottom Left)
          Select Stapling Position (Top Right)
          Select Stapling Position (Bottom Right)
          Select Stack Position
          Select Punch Type
          Letterhead Setting
          Eject Copy Face Up/Down in Glass Mode
          Eject Copy Face Up/Down in Bypass Mode
          Hope this will help you,
          Regards
          • tcs04
            FORMER Techie
            • 1183
            #20
            You went on an electronics course!!??
            Me Too!!! DOH!
            • FRIDGEMAGNET
              • Aug 2007
              • 377
              #21
              Originally posted by Ricohlovers
              This is only for copies placed on the glass not via the DF.
              • tcs04
                FORMER Techie
                • 1183
                #22
                Benim ve havada gidebilen taşıt Eels dolu!
                • can06
                  • 22
                  #23
                  aficio 2075
                  shortly i meant, i can flip the paper face up and down in the glass copy, i can flip the paper face up and down in the bypass copy but whenever i try to use the SADF copy mode i got the copy product only one type, the copied face is down, i can not change mode to that copied face up in ADF copying. since machine's digital menu is German, i can not understand how to adjust that option. please help..
                  RICOH Pro C900s
                  • Jomama46
                    • 2900
                    #24
                    Its programmed like that to keep the copies in the original order. You can change that in UserTools>Copy/DocServer Features>InputOutput>Eject copy faceup/facedown in Glass: or DF mode. Cant help you on the German stuff.
                    sigpic
                    A+; Network +; PDI+
