Noise in Ricoh AF 3245c
Have you gone into output mode (sp 5-804) and tried the fans, motors etc to elimiante the various parts and you can also try the waste toner vibration motor in output mode. -
Input mode will not help you much. You can check the aforementioned components with Output mode as banginbishop suggested. Good luck.NEVER ASSUME ANYTHINGComment
I have a lot of these in the field and most noises come from the finisher which squeals just about everywhere but if you know it's a machine squeal than my bet is that is the upper transfer belt drive roller. Usually in the front. Pull the transfer belt out about half way and oil that silver bearing and the surrounding ones. You will know right away if that's it or not.Comment
Huge thanks, it was from the transfer unit this irritating sound.
Sillicon fluid in the bearings/moving parts transfer unit and the
sound was gone.
