mp 2510 sc 670
  • ash_572
    • Oct 2008
    • 523
    mp 2510 sc 670
    machine freezes with a please wait message then after a minute the sc 670 appears. disconnected the hard drive with no luck. checked the sbcu and seems allfine and connected. ther is an rtb on this code to update the firmware. have i missed something out or does it really need an firmware update??
  • Eric1968
    • 2459
    I checked the Tessa-support website and there is an RTB for this SC, but this RTB applies only to the AF3025/3030. When you do a remote firmware update on an AF3025/3030 SC670 could occur. I would try to update the firmware with an SD-card.
    Good Luck
    • ash_572
      • Oct 2008
      • 523
      cheers.
      • tcs04
        FORMER Techie
        • 1183
        RTB 10c on TESSA.
        This was a classic fault on the AF1035 series (precisely as you described) and WAS caused by the HDD!
        In this case it does sound like a bad connection.
        Had a similar fault (I caused it!) just yesterday when refitting covers, I tweaked a duplex harness plug and caused SC650 due to a bad connection on one pin.
        Try removing everything (including the ADF) and re-booting in stages.
        • tcs04
          FORMER Techie
          • 1183
          Also, just checked the Knowledgebase (TESA / Knowledgebase2) and found loads of references to SC670.
          It is always related to boot errors and can relate to connection problems / NVRAM failure and board failure.
          As a quick check(?) it may be an idea to take the NVRAM from this machine and swap into another machine?
          • ash_572
            • Oct 2008
            • 523
            forgot to mention. i disconnected the duplex and the DF and the messgae sc 670 still ocurred.
            • flo
              Engineer
              • Mar 2009
              • 44
              SC 670
              I had this problem by two Machines, i make the way about hdd controller Firmware Etc. And whats coming out SC 670
              I look in SMC and i found in History bad connection to Printerunit
              i look the Fusing and its really go very hard . after changing Pressroller and Ball Bearings this Problem never come up
              • TonerMunkeh
                Professional Moron
                • 3873
                Controller board's gone, the newer machines do this a lot.
                Hit it.
