SR4010 jam181
  • FFFF
    • Jul 2009
    • 43
    SR4010 jam181
    Hi
    we have an MPC7500 and an MPC6000 both with an SR4010 finisher. On longer runs 100+, to the finisher tray both give jam 181 ( shift roller motor sensor error ). Both new machines, have updated f/w, repl. finisher pcb, repl. motors, have swapped shift ay for working one - no joy - any ideas?
  • FFFF
    • Jul 2009
    • 43
    Still an issue any ideas ??
    • Vulkor
      • Jun 2009
      • 946
      Having the SAME DAMN Problem with ours. Savin told us replace the Shift Roller motor and Grease that shaft well. Did Both, haven't heard back from customers. BUT they may not be calling us.. who knows
      • tcs04
        FORMER Techie
        • 1183
        Originally posted by FFFF
        Hi
        See attached.... Worth invesigating?
        • FRIDGEMAGNET
          • Aug 2007
          • 377
          These finishers do have problems with the tray lift motors especially on sites that like to do long runs and leave the tray filled up, this seems to put strain on the motor and it gets erratic.
          • Vulkor
            • Jun 2009
            • 946
            Originally posted by tcs04
            See attached.... Worth investigating?
            Where did you get this Bulletin? Is England TSC different than US. I looked under Accessories\Finisher and Didn't see that one.
            • tcs04
              FORMER Techie
              • 1183
              Originally posted by Vulkor
              Where did you get this Bulletin? Is England TSC different than US. I looked under AccessoriesFinisher and Didn't see that one.
              Just by skimmming thru' the tech bulletins on the Ricoh uk TESSA (Tech) site. I'm not even sure if it relates, haven't check where the part is on the finisher, but.........? Good luck!
              • Vulkor
                • Jun 2009
                • 946
                Weird, Guess UK does have different sight. US is TSCweb.net
                • FFFF
                  • Jul 2009
                  • 43
                  Hi Chaps - I've tried swapping shift tray lift motor ay - no joy. And the RTB ( ricoh tech. bul. ) refers to the lower limit sensor bracket for the shift tray.
                  • Milkyt
                    • Jul 2009
                    • 2
                    SR4010 Jam code 181
                    Hi Guys, This problem can be for a number of reason, but I would think yours is down to the Height guide sensor being out of position causing erratic operation and intermittent jamming, in your case 181. This does happen on other type of Ricoh finishers and will log a different jam code dependent on the finisher type.
                    • FFFF
                      • Jul 2009
                      • 43
                      So far so good Milkyt
