Has anyone ever met a the problem with the PCU charge roller cleaning roller wearing out and hence leaving lines on either side of the copy. This is happening at around 40K and then the Drum unit has to be repalaced as the roller is not available by itself or as an assembly. Please note that this roller can not be touched as the foam will just fall off. The first time I tried to vacuum it and the foam was stripped off. Its a pity as the drum is always in good condition and could probably outrun the PM of 80K.
MP C2500 lies on sides
You can place K drum unit instead colors (K is chipper), just cut a little bit the RJ11 plug.Comment
Has anyone ever met a the problem with the PCU charge roller cleaning roller wearing out and hence leaving lines on either side of the copy. This is happening at around 40K and then the Drum unit has to be repalaced as the roller is not available by itself or as an assembly. Please note that this roller can not be touched as the foam will just fall off. The first time I tried to vacuum it and the foam was stripped off. Its a pity as the drum is always in good condition and could probably outrun the PM of 80K.Comment
I agree the charge roller cleaning is a short lived fix. Even with our low volumes it will not last a week. The real question I was leading to is dose any one know where we could find foam roller replacement. This would be a great bonus as was the knowledge that we could use the black drum for all 4 units by just modifying the RJ45 or change it with the old one. We could probably get another 20 to 40 k prints out of these drums and I bet Ricoh know this as well but due to envisaged revenue on sale of consumables they will not supply the parts.Voluntary assistance can be your greatest gift once you do not degrade the recipient.
If you want a part that is not listed in the parts catalog, just go on-line to the parts knowledgebase and search for it. If it isn't there, ask for it.
More often than not, they have given me the number for a part that I wanted. If they don't hear from you, they won't make it available.
So simple!!Comment
MP C2500 lines on sides
I have never heard of Parts Knowledge base from Ricoh Europe that is. Will ask them about it. In the mean time if anyone gets hold of the part number, I'll be more then happy to hear about it.Voluntary assistance can be your greatest gift once you do not degrade the recipient.
Ask an ye shall receive.Comment
