2232c sc 393-002
  • ash_572
    • Oct 2008
    • 523
    2232c sc 393-002
    i recently changed the yellow developmet unit because it was well passed its life span. since then iv been getting this code like nearly everyweek. the unit that i changed was brand new could it be possible that it may be faulty?
    is there somthing that i need to check? or am i just better off just replaceing the unit again?
  • rthonpm
    • Aug 2007
    • 2854
    Did you re-set the PM counter to initialise the unit when you installed it?
    Also, do the gears in the back of the dev unit turn? If not, it may be a faulty one. They don't cost that much so just dump it and get another one if the gears are locked.
    • ash_572
      • Oct 2008
      • 523
      yes i did reset the pm counter to initialize the unit.
