MPC 1500 sc 202
  • ash_572
    • Oct 2008
    • 523
    MPC 1500 sc 202
    customer complained that the magenta was not printing. did the head cleaning 3 times. still the same. printed the nozzle test patern and the magenta was completley blank. tried to flush the magenta head and i ended up with the sc code of 202.
    checked the ink full sensor and it seemed alright. am not an inkjet expert i just happen to have more experience on these types than any other engineer where i work.
  • aabarnes1
    • Mar 2009
    • 620
    Had this exact problem last week. I changed the maintenance unit and waste ink tank, reset the pm counters and reset the waste tank b counter in sp 2xx.
    There is also a tech bulletin re the print head carriage where you have to take it out and push the slider down with a small flat blade.It's in the service manual on the disk
    Grant me the serenity to accept the things I cannot change.
    • ash_572
      • Oct 2008
      • 523
      also i couldnt get into service mode. the 0 button wouldnt work is there another code that i can try?
      • aabarnes1
        • Mar 2009
        • 620
        Ah! Sorry, I don't know. But if there is a way you're sure to find out on this site or from the 'experts' at Ricoh.
        • ppetr
          • May 2009
          • 9
          replaced maintenance unit and still no difference
          • TonerMunkeh
            Professional Moron
            • 3873
            Try a super flush in SP modes. If that doesn't work it's a new engine unit.
            Hit it.
            • ash_572
              • Oct 2008
              • 523
              its now bought up an sc 310.
              • TonerMunkeh
                Professional Moron
                • 3873
                310 isn't listed in the manual. Do you mean 210?
                Hit it.
                • ash_572
                  • Oct 2008
                  • 523
                  sorry. its sc 210
                  • TonerMunkeh
                    Professional Moron
                    • 3873
                    That's the main scan encoder signal error. This little machine sounds rather miffed at itself at the moment. Replace the engine unit and look at the main scan encoder too.
                    Hit it.
                    • ash_572
                      • Oct 2008
                      • 523
                      im trying to fix it without having to replace the engine unit. engine for this type cost about a grand.
                      • iMind
                        Vacuum Cleaning Expert
                        • Mar 2008
                        • 1116
                        • aabarnes1
                          • Mar 2009
                          • 620
                          You mentioned in an earlier post that you could not enter sp mode? if that's the case then there is no point in replacing any parts in this machine as you need to go into sp mode to tell it that you have replaced the maintenance unit/engine/waste tank etc. The encoder wheel can be cleaned carefully with alcohol. I would't just jump in and throw a new engine at it as previously suggested. We're notall in a position to throw parts at a machine and hope it fixes it, know what I mean!!!!! Let us know how you get on with this cos we've had a few problems with these bags of shite aswell, good luck.
                          • TonerMunkeh
                            Professional Moron
                            • 3873
                            Don't clean the encoders with alcohol! Use water!
                            Alcohol takes the coating off the strip and wheel and makes them unreadable by the sensor.
                            Hit it.
                            • ash_572
                              • Oct 2008
                              • 523
                              ive replaced the whole keypad. service mode is working.
                              already cleaned the encoders with alcohol and still the same. encoder looks clean anyway.
                              not many engineers know much about these machines coz these are a pain in the ass to work on.
