AD420 actuator popping out
  • Scott_Lewis
    • Mar 2007
    • 519
    I've got a MP2510 with the attached duplex unit that has dislodged the actuator to the inverter gate a couple of times. At the time of the first service call, I was unable to discern what was causing the problem. So, I swapped out the entire AD420 unit. A day later, the same thing happened to the new AD420.
    The actuator circled in the drawing gets dislodged. I'm at a loss how this could happen on two different duplex units.
