Hello friends,ihave aficio 350 & it gives sc 542, inoticed one heater lamp is not functioning,i checked heater lamp & replaced power supply board,even connection from power supply board to fixing unit is ok,what do you think is the other possible cause, please help,thank you.
Aficio 350-sc542
Hi.
SC 542 is problem with thermistors . Go to SP mode (5-810) and reset sc code.If machine dos not have (5-810) then only to exclude button OFF/ON and then wait 20 second . After this start machine .If the machin stil have
this SC code then change the THERMISTORSComment
Replace the thermal fuse. They check fine with a meter but can't pull the current of AC when bad.
Put a paper clip in just to see if the lamp turns on.
DON'T leave the paper clip in the machine.Why do they call it common sense?
If it were common, wouldn't everyone have it?Comment
Check your machine and see if the Thermostat has tripped if so take it out and knock it hard on the floor till you can feel it is not dented in any more. If you still have no joy the you will have to look at you BICU board or your fusing unit connector sometimes one of the little pins bend.
What? HuH?Comment
Another thing...... it is possible for the lamp to ohm out ok when its cold. Conductors flex when they get hot.Comment
