In this thermistors/thermostats issue are to many variables and in my opinion it's not just only one solution for our problems. Sometimes you can fix it just replacing the thermistors...sometimes just forcing the fuser to idle way longer than usual....(this one is actually the best) cause it's cleaning the thermistor from debris.
When you are out of solutions after replacing the thermistors, thermostats...checking the lamps connectors, fuser harness, try to increase the idling time SP 1103-01, 02, to 60 sec and 3 to 120 sec. If still no results try to turn off AOF and also turn the Panel timer off...
