That setting should be under the user tools. I believe there is some sort of initial mode or primary mode setting....I don't have the user tools manual downloaded.
Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
In user tools I have the copier set under function priority for copy. The copier is going into the scanner function. This should only happen if scanning is chosen. Any thoughts???
Thanks!!!
If the function reset timer is the problem how would that cause the copier to go into scanner mode when it's set for copier in Function Priority in User tools???
What mico switch???
Thanks!!!
Not all all of course - I didn't get that from the initial post
In this case it's a good hint to solder another scanner function micro switch on the panel PCB. If the machine has not a fax option you can simply move one of the unused micro switches and dispose the (probably) defective one.
