savin 9935dp
  • T911
    • Jun 2007
    • 628
    savin 9935dp
    can i remove the optional hdd off this one. getting 360/890 codes. tried to format and reset with 4911 but no luck. if i can possibly remove the hdd do i need to change a setting so the machine knows there isn't one on it now. and is the # a6915878. thanks t
  • scepter2112
    • May 2009
    • 72
    I believe that was an option on Machine, so you just disconect it.
    • copytechman
      • Nov 2008
      • 943
      If it's like an aficio 350 you can't just take the hdd out, u gotta remove it's controller too (plugs into the main board.) Otherwise the machine keeps lookin for it.
      Regards!
      A.
