AF 1515 scanning through USB.
  • Patish
    • Aug 2008
    • 66
    I've attempted scanning through the USB but no luck. Ricoh has no TWAIN USB driver for this model. Is there a compatible driver ?
  • Fearless V K
    • 620
    I think scanning is network only on that model.
    Don't take that toner with me!
    • Patish
      • Aug 2008
      • 66
      Heh, customer has two separated networks. From the inner one they print from different PCs through the LAN. The inner network has no gateway to the Internet. The box that has access to the Internet, print through the USB. But they wanna send scanned docs to the outside e-mail addresses. I've wasted 3 hours today with no result.
      • Fearless V K
        • 620
        Why can't they just connect the machine to the network?
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          There is no scan to USB on that model as mentioned. Newer models can.
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • Patish
            • Aug 2008
            • 66
            Copier is already connected to the inner network.
            I'm going to say them just use a disk-on-key.
