ricoh 4015
  • gregoryk
    ricoh 4015
    hi friends i am new here i have a problem with ricoh 4015.Indicates toner empty and p.e together any ideas?
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment
    from http://www.justmanuals.com
    Paul@justmanuals.com
    • daveyball
      • May 2009
      • 314
      Thats an old one, the mylar guides in the toner hopper used to come off, stopping the supply to the dev unit, take the chuck apart and you may see the mylars. You'll have to replace them if you can get them
      • daveyball
        • May 2009
        • 314
        Just had a thought about the paper end, the cassette used to wear and not lock in properly, push in and down motion it used to stop the paper lift mech form working. If you shove the cassette in hard and push dowm and it works, then thats the fault, again you'll have to replace the cassette.
        Hope this helps
        • gregoryk
          thanks for the advise i'll try it and let you know
          • samiranbairagya
            • Nov 2009
            • 16
            Problem resolved ?
