Ricoh mpc 2500/3500 drum units
  • Lagonda
    • Aug 2008
    • 1649
    Originally posted by abenford
    Lagonda.
    If you are going to be insultive. Atleast have the decency to spell words correctly.
    Sorry about the typo abenford, I didn't run spell check.
    By the way we are all still waiting to find out how much you want to charge, we could all do with a good laugh!!!
    "insultive" ???!!!!
    • turbojetboy
      • Aug 2009
      • 279
      Aussies told to mod drums.
      In Australia we are told by our (direct) branch supervisors to mod all drums (with the 5 second side cutter method). This is to save money. It seems to work ok.
      • knightfall
        • Jul 2006
        • 633
        I usually just remove the connector from the old color pcu and put it in the new black pcu, takes a couple of minutes but it wouldn't result in a bad cut into the connector or a cut the wrong size.
        Get your facts first, and then you can distort them as much as you please.
        • sakura
          • 132
          #19
          It seems like there are a lot of smart people around here. But DO NOT forget that if your copiers (Ricoh etc.) are stiill under a warranty coverage and if someone from Ricoh tech dept. will find out that you've replace original PCU with a diff. model they will have all rights to VOID your warranty right away. Keep it in mind. Is it worth a try? Don't think so. Another thing if you copier has no warranty anymore - here you go you can do whatewer you want... even use a hammer to smash it twice if you don't like Ricoh so much
          • zyqwiz
            • Jun 2009
            • 333
            #20
            You can't swap the looms over now unless you have very old stock - the plug is glued on now.
            As for warranty, they are PM items which are excluded from warranty of any kind in the UK now unless it fails straight out of the box!
            • sakura
              • 132
              #21
              The warranty I was talking about is the warranty in general not that which covers parts from the box.
              • Saviour
                • 57
                #22
                jokes or insults apart, it seems that the thread has lost direction. Could we give the guy a chance to explain himself and perhaps learn something new then we can all comment.
                Voluntary assistance can be your greatest gift once you do not degrade the recipient.
                • zyqwiz
                  • Jun 2009
                  • 333
                  #23
                  The general warranty doesn't cover consumable parts
                  • andym
                    • 90
                    #24
                    I have a supply of new drums. I replace the drum, with compatible yes. I also replace the drum cleaning blade and coating bar. I clean the charge roller. Have not had any problems yet.
                    My boss would skin me alive for discussing prices. So I'm just going to say... A hell of a lot cheaper.
                    The only thing I need are the cover plates. The ducking holder for the locking clip keeps breaking.
                    • Saviour
                      • 57
                      #25
                      That sound interesting. Just one question what about the charge roller cleaning roller. Most of the times I find that this wears out at the edges and can not be cleaned as it crumbles.
                      • andym
                        • 90
                        #26
                        Compressed air. Once the unit is apart and the brackets for the cleaning blade are put away safely the whole unit is air dusted.
                          • 23008
                          #27
                          Sorry for reviving this old thread.
                          I'm finding the drum blades are not lasting very long (15k or less). Cleaning & re-priming the blade doesn't help at all. So far all that I've found is assemblies. What I would really like is the drum cleaning unit or the blade only. The lower seal and drum and primary seem to be fine. Where do you purchase the blade or cleaning unit separately? =^..^=
                          • collme
                            Ricoh tech
                            • 221
                            #28
                            re ricoh techs replacing colour units with moded blacks, i have been told that we have to fit colour pcu's to colour and black to black. only takes a slip up on cutting/sanding the connector wrong and you have a full gearbox in the back of the machine to replace. my old company did the mods but was a horrible job when one engineer smashed the connector in the back of the machine.
                            • msaeger
                              • Sep 2008
                              • 333
                              #29
                              Yeah you have to be careful if it doesn't go in file some more off. I haven't broken one yet.
                              • collme
                                Ricoh tech
                                • 221
                                #30
                                also by doing the dev change followed by dev unit change when they hit life, the pcu's will last longer. many engineers are running the dev units thinking there is no problem as the c/q is ok, if they are left past life then pcu's will not last life.
