MPC6000 jam power on..
  • MrRicoh
    Hi
    Hope someone could give me a tip on this problem.
    The machine indicates jam in D ! witch is somewhere around the fuser and jamcode 1 (power on) when it recovers from sleepmode ore startup (not every time). To restet, I have to open and pull out the fuser...have tried changing the sensors (3) around the fuser and cleand all the others. Have changed the interlock swiches at the door and cleaned the sockets (fuser) and in the machine...
    Have someone had the same problem
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    sounds like a firmware update
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • Jomama46
      • 2900
      Agree, I think there is a firmware update for powering on with the ADF up and it causing a fuser code.
      sigpic
      A+; Network +; PDI+
      • Polo-022
        • Sep 2007
        • 486
        Exactly the same problem but it was an MP-6000, brand new. It was the fuser exit switch harness giving that symptom. The grey harness, wich was very stressed from photointerruptor to the connector located at front left of fuser area...Different constructions but the same experience!!
        • MrRicoh
          Ok thanks Polo..I check that out tomorow....And sadly the machines has the newest firmware...
          • tcs04
            FORMER Techie
            • 1183
            That was the MP6000 (and subsequent models) Not the MPC (unless I missed it)
            new Engine firmware was released about 2 weeks ago
