savin 2060/ricoh 7960
  • copyman
    Owner / Technician
    • Sep 2005
    • 4616
    machine has 160k on it and was used very little as you can see by count. now machine is in a different dept and is being used more, about 20 to 30k month. the customer called and said that alot of codes and jams are happening so i went out and noted codes. is there anything common that will relate to the following codes? with this many different codes in a month and half (i cleared codes sept 6)could it be needing a surge protector or does this machine have a way to update firmware? they have always had the SC 522(jogger hm pos sensor) when trying to duplex. i replaced the hm pos sensor & jogger motor last year but it still throws this code once in awhile. i just renewed the contract because last year only needed 3 calls, now they are calling every 3 days!!! any help with this greatly appreciated. here are the codes:
    SC124 scanner motor/encoder 13 times code came up
    125 scanner- 1 time
    126 scanner- 2 times
    129 scanner- 1 time
    302 charge corona- 3 times
    356 toner- 5 times
    402 trans short- 8 times
    522 jogger/hm pos sensor- 14 times
  • copyman
    Owner / Technician
    • Sep 2005
    • 4616
    Re:savin 2060/ricoh 7960
    anyone have the scanner motor for this, new or good used to sell? part# AX06-0154. thanks
