Anyone knows if it is possible to eliminate white lines from these machine's AIO cartridges? Or is it pretty much a lost cause? Anyone disassembled one successfully to solve this?
SPC222SF and similars: White Lines
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation! -
You could try backing the mag roller up unitl the dev is off, then roll it the right way until the brush comes back a few times. I find this works sometimes.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it. -
Haven't tried it on this particular machine before, but when I get void areas in the dev roller, I've tried sliding the corner of a sheet of paper between the dev roller and doctor blade and rotating the dev roller in the normal direction. Start with the paper corner to the inside of the void area and move the paper to the edge while rotating. Sometimes, I will curl the very tip of the corner up to get behind the doctor blade better. If there is a clump or debris or whatever, it will get broken up or moved to the nonimage area of the dev roller.Comment
