''Independet-supplier toner cartrige is set''
  • bostjanma
    I want to ask you, what is wrong with MPC4000 if notice this mesage: ''Independet-supplier toner cartrige is set''? We always use original ricoh toner! If posible to reset this mesage before change with new toner cartrige?
  • paulg
    • Jun 2007
    • 278
    Originally posted by bostjanma
    SP mode 5051 will help you hide message
    • teebee1234
      • 1670
      If the user inserted a previously used toner bottle (to use up one that still had some left in it), you will get that indication. A new, unused bottle will get rid of the message. FYI, I always tell my customers to replace the toner when the mfp stops due to 'out of toner' condition, not when the display says 'toner low'. There is usually about 10-15% left in the bottle.
      • Fearless V K
        • 620
        X2, set 5051 to 1. These machines have issues with this.
        Don't take that toner with me!
        • zyqwiz
          • Jun 2009
          • 333
          The toner chip will have been damaged in transit - is it back door original toner? They always get kicked all over the place and are more likely to fail due to the extra shipping.
