Okay, machine shows no error, but when client prints full color we really only have good density on op side of print for yellow, non op is washed out, very light.
had similar problem with lanier printer lp440c where the itb was dumping toner
toner had found it's way inside the laser unit and on to the mirror for yellow
Try replacing the transfer unit, we have seen that several times, even with new units, the frame of these units is flimsy.The transfer rollers for each color may break loose causing one color, or only on one side to lose transfer.
I have to agree with duct tape. Let us know what fixes it.
Just encountered this problem today with a newly installed ITB unit, half of the cyan(image) when printing SP 1103 color pattern is very light. Disassembled it(ITB) and found out that the image transfer roller was out of position. fix it then problem was solve.
