Aficio 2035e "Z" folds
  • poz31
    • Aug 2006
    • 86
  • Jomama46
    • 2900
    Check the hot roller gear, they have a bad habit of rounding out the D shape.
    sigpic
    A+; Network +; PDI+
    • pocket aces
      Ricoh Technician
      • Nov 2008
      • 72
      relay clutch......while your there I replace tray 1&2 paper feed clutch
      • GhostInTheMachine
        • Feb 2010
        • 88
        I agree. Seen this dozens of times.
        • kopiket
          agree to RELAY CLUTCH. good luck
          • nmfaxman
            • 1705
            One more for relay clutch sticking causing overdrive.
            • scepter2112
              • May 2009
              • 72
              Oh and what fun it is to change that Clutch.
              • andy1mack
                Senior Technician
                • Jun 2010
                • 17
                BINGO Guess that answers that. Next!
                • tcs04
                  FORMER Techie
                  • 1183
                  Change the Transfer belt and blade.
                  • Vulkor
                    • Jun 2009
                    • 942
                    I will be interested to see what the fix is. Z fold/accorrdioning has always been fusers for us.
                    • pocket aces
                      Ricoh Technician
                      • Nov 2008
                      • 72
                      he didnt say accorrdioning.......Z fold to me is one fold in the middle of the page.....accorrdioning is when its in the fuser stuck on a finger.....
                      • Vulkor
                        • Jun 2009
                        • 942
                        Then never had the misfortune of a Z Fold.
                        • Jomama46
                          • 2900
                          I use the two interchangeably.
                          sigpic
                          A+; Network +; PDI+
                          • tcs04
                            FORMER Techie
                            • 1183
                            If the Transnfer belt and blade are old they will grip during a long run. This will stop the fuser drive and cause Z folding.... We had one doing this, maybe after 150-200 copies and a new belt and blade cured the problem.
                            • b003ace
                              • Jun 2008
                              • 78
                              Z fold in 350/1035/2035 et al
                              Registration clutch is bad, while you are in there, change out the relay and feed clutches, so you don't have to go back in again anytime soon.
                              2 of EACH clutch - AX200280 and AX200281
                              See also the more recent thread about 1035 z folds
