mpc 2500 firmware update
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    Hi guys, i am going to update the firmware on one of these machines and i know that you can upgrade the firmware via the web browser. My question is which firmware do you use, is it the remote one or the usual one?? (there are 2 types on the download site)
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    If your going to do the remote firmware upgrade you use the firmware known as .rfu files. If you use the SD card use the .fwu files on the card.
    Mystic Crystal Revelations
    • leo34staffs
      copierman
      • Aug 2007
      • 503
      thanks
      cheers for that i will upload the firmware to it tomorrow, it beats getting out an sd card
      • rthonpm
        • Aug 2007
        • 2854
        Be careful when loading firmware via the network. If a print job is sent or a fax comes through at the same time, very bad things will happen.
        • unisys12
          • 489
          Well, the easy way around this is to carry a crossover cable with you. Oh! And a laptop. Other than that... Just stand up in a chair, look out across the sea of people and yell, "No one print to this machine until further notice!"
          Joking aside, I have yet to perform this task. I wanted to the other day on a machine that I was working on in house, but did not get around to it. I have a machine that I want to set-up a remote firmware update through @Remote also. The machine isn't that far away and used sparingly so, I figured if something went wrong, it wouldn't be that big of a deal to get the machine going again.
          I do all our updates through the use of the SD card method, when applicable. I have a 128 meg card with most all the machines different firmwares on it. This way, I just pop the card in and the machine does the rest. Anyway! Hope everything goes well with your update Leo!
          sigpic
          The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
          • hosennet
            • Mar 2007
            • 145
            Hi someone help me . About firmware for RICOH MPC 2500/3000 .I need it.
            If you has it send to me please
            Thanks first
            Email:hosennet@gmail.com
            Best regards
