I have a D038 (Lanier 520c) that is scanning in an all Mac environment. All the systems are using the latest version of OSX. It has been scanning diretly to their computers fine using FTP and using the IP Addresses of the stations. Recently, due to the IP addresses occassionally changing, they have given all their workstations SMB-Friendly names. All the scan directories are set up to share using SMB and a common user for the copier has read and write access to them. However, when the copier is set to scan using SMB it can not connect to the workstations. I thought that it was not resolving the host names, so I configured the WINS server info into the copier, and the control panel displays "NetBIOS name is in use." It displays this message no matter what is set in the Host Name field of the copier. It should be noted that they are running a MAC server, and I am uncertain about how WINS is configured on it. DNS is configured on their server, and is set as the DNS server for the copier.
I've also tried entering the IP address in the SMB share (\\192.168.2.1\users\user\scans) and it does not work either. The communication light blinks for a second then the status changes to "waiting" FTP will also stop working if you substitute the IP address with the Host Name.
Wondering if anyone has had any experience with this, namely working with a MAC Server.
